Determination of DMF in water, using GC.
Posted: Thu Feb 08, 2007 10:17 am
Hello all
I've been trying to estimate dimethylformamide (about 15% w/v) in an aqueous sample matrix, under the following conditions:
Column: DB-624 30 m
Carrier gas: N2 at 40 ml/min
Injector temperature: 200 deg C
Injector split ratio: 50:1
Injection volume 1 ul.
Detector: FID at 260 deg C.
Column oven temperature program: Initial 70 deg C, final temp at 225 deg C, @ 25 deg per minute.
Sample: DMF (about 15% w/v) in water or MeOH.
DMF elutes at about 7 mins.
Problem is, the peak tails badly, and I'm not getting reproducible peak heights.
Help!!
Column: DB-624 30 m
Help!!
