Pressure on a 5890
Posted: Wed Feb 07, 2007 6:20 pm
Hello people-
I'm trying to run an HP 5890 and for some reason my pressure isn't holding on the front injector.
I've done (and redone) all maintenance to make sure that everything was screwed in and seated correctly. Checked for leaks using a leak detector and found nothing.
Checked and double checked: septum/o-ring/injector nut/ferrule/Presstight connector
Any suggestions? I'm trying to think of whether or not I've overlooked something, but it seems like I've tried everything.
