Relationship between temperature and volatility
Posted: Tue Feb 06, 2007 3:25 pm
Not strictly GC I know but it might have a bearing on this problem.
I am analysing some fabric for a client. The fabric has been treated with a solvent then left to dry. There are residual impurities left. The client claims that these are removed if left for several days at room temperature. My analysis shows that there are residual volatile material impurities left on submitted samples of fabric that have been air dried at 50°C for 30mins.
My question is (here comes the GC related bit - let's call it paper chromatography
) what is the relationship between volatility and temperature likely to be.
e.g. for every 10°C increase in temperature does the rate of volatalisation double? This happens with chemical reactions and just reflects the increased speed of molecular motion thus leading to increased chance of collision/reaction.
Could we then predict what temp/time would be required to equal 5 days at room temp (with a forced flow)? Assume that the forced flow is constant, and that we can't go over, say 100°C.
Regards and thanks in advance for any thoughts,
Ralph
Ralph
