connecting PE 785A UV/Vis detector to chart recorder
Posted: Wed Jan 31, 2007 8:53 pm
Does anyone know how to connect a Perkin Elmer 785A UV/Vis HPLC detector to a standard analog paper chart recorder? My chart recorder has input wires (one black (grnd), one red (positive)) for connection to detectors with analog output.
The back of the PE detector has various wire connector outputs marked CO C1 NC; CO C2 NC, etc. as well as 30 mVDC and COM outputs. In addition, there is another output marked REC OUT 10 mV, but it is a headphone-style port.
If anyone can offer any advice on how to connect the two, I'd be greatly appreciative.
