Soft and Hard Gel Capsules - Sample Prep Technique
Posted: Mon Jan 29, 2007 7:44 pm
Hello all,
After spending the last five years performing analytical method development on creams and ointments for a dermatological company, I now find myself working for a different company doing similar analytical development work, but on solid dosage forms, particularly soft gel (and eventually I suppose) hard gel capsules.
These dosage forms are completely new to me, so I was hoping that some of the more experienced members of this forum might shed some light on the techniques they use to sample these capsules. Since I just started my new position, I've been reading the internal documentation and talking with other people here. It seems the standard procedure they talk follow includes "piercing the shell and squeezing the contents into a vol flask" and then "cutting the capsule in half and adding these halves into the vol flask". Diluent is then added, followed by shaking or sonication to complete the extraction. I have tried this and it is not easy, with much of the liquid fill material ending up on the tools used to grip, pierce, and cut the capsules. This of course leads me to believe that there could be a recovery issue eventually with this technique.
So my questions are: Is this the standard technique for soft gel capsules? Are there other alternatives that might be easier?
Again, I come from working with creams/ointments so capsules are new to me completely. I'm not looking to re-invent the wheel, so hopefully someone can offer some suggestions.
-Blazer
-Blazer
