validation-peak distorted
Posted: Sun Jan 28, 2007 9:01 pm
Column Hypersil thermo C18 BDS 5 um 4.6X250 MP: phosphate buffer 3.8 pH and ACN gradient 10% ACN to %70 ACN in 50 minutes. Compound is nonpolar. Degs assay. compd conc. is .48 mg/ml.
The peak is tailing. with different column lots it shows double peak, peak tailing. The other problem is chromatogram shows lots of small peaks around that compd. ret time is around 46 mins. How can this be resolved.
Validation did not pass. We have other five degradants in the same method eluting at 15 minutes to 25 minutes well resolved peaks. Polarity is ranging from somewhat polar to non polar.
Any guidance will help.
