HPLC baseline
Posted: Fri Jan 26, 2007 9:17 pm
I am developing HPLC method for a drug and its metabolites. I have to use gradient since the great difference between the parent compound and its metabolites.
The mobile phase is A: 30% acetonitrile (0.2% acetic acid, pH 3.6), and B: 90% acetonitril. The gradient is:
keep 90% A for 5 min, gradually increased to 90% B within 25 min, then stay at 90% B for another 10 min before return to the 90% A.
The parent compound and its four major metabolites (M1-4) were perfectly separated. Retention time was about 6, 7, 9, 11 and 42 min for M1-4 and parent compound, respectively.
The problem is, as you see, the parent compound come out too late. And there are several unknow peaks come before the parent compound. There are also unknown peaks when I run the mobile phase alone. I also wash the HPLC system but they are still there. So, what can I do to get rid of these unknown peaks?
Another problem is the baseline droped steeply during the gradient running, from 0 to -1.5 AU. It's so ugly chromatogram.
Very appreciate any kind of help.
Ru Yan
UTMB, Texas
Ru Yan
UTMB, Texas
