EPA Method 548.1 (Endothall) [June 17, 2004]
Posted: Mon Aug 30, 2004 5:01 pm
by admin
By Anonymous on Thursday, June 17, 2004 - 02:20 pm:
Is anyone in here familiar with EPA Method 548.1? I am using a DB-624 column and an FID detector. I am not seeing any peaks, though. The column was working fine with TPH samples, but I can't seem to get any endothall or internal standard peaks. Any suggestions would be appreciated.
By B.Buglio on Tuesday, June 22, 2004 - 05:01 pm:
Do you get a peak for the calibration std dimethyl
endothall?
By Anonymous on Wednesday, June 23, 2004 - 11:20 am:
I calibrated using standards that were extracted; I also added an internal standard. I did not see anything consistent in overlays of the chromatograms.
I was advised to order an endothall standard that does not have to be extracted (the dimethyl endothall) as a reference point for the extracted curve points.
Hope that will work.
By B.Buglio on Wednesday, June 23, 2004 - 04:00 pm:
Your headed in the right direction wrt
troubleshooting the problem - good luck
