Help with Ramipril Assay by Normal Phase
Posted: Thu Jan 25, 2007 11:30 am
After working on a reverse phase method for ramipril successfully for several months now, I now find myself needing to do the same but by normal phase due to a change in sample matrix.
I've initially tried this on various ratio's of hexane:IPA but found that the peak shape was appalling, ramipril tailing massively.
Therefore I switched to Hexane:THF this gave what I took to be a ramipril peak for sample preparations but gave either a much reduced or no peak for the equivalent standard.
Any pointers on likely conditions etc would be greatly appreciated
