Importance of Elution Order in e.e. determination
Posted: Tue Jan 23, 2007 9:26 pm
Hi there,
We were looking into buying a few Pirkle phase columns from Regis Technologies; mainly Whelk-01 and ULMO (possibly DACH-DNB as well). As some of you may know, these phases are available in both the (R,R) and (S,S)-forms, thus allowing the invertion of the elution order of the enantiomers by simply switching columns. We are told that "this advantage is *essential* when determining enantiomeric purity when the trace enantiomer should elute before the major"... Is this absolutely necessary? I don't understand the statistical basis under this one...
We're mostly inquiring because if we get only one enantiomeric form of each type, we can get a wider variety of columns with our grant than if we get both (R,R) and (S,S) of each.
I mean, quite logically, other types of columns (such as Daicel's cellulose columns) will only lead to one separation, with no inversion of elution possible... So why would it be such an essential advantage in this case?
Just looking for opinions...
Trishia.
Trishia.
