A collegue of mine has a couple of questions:
What column lifetime should be expected for Restek BAC-1 and BAC-2 megabore columns when used for blood alcohol analysis by the headspace method?
Is an oxygen trap necessary when operating Restek BAC-1 and BAC-2 megabore columns (for blood alcohol analysis by the headspace method) if the operating temperature doesn't go above 40 degrees Celsius and the carrier gas is hydrogen containing less than 10 ppm oxygen?
Thanks in advance
Taras
