Retention Index and Alkane Standards
Posted: Sat Nov 18, 2017 10:34 pm
For teh first part of my career, most of my experience had been LC, so when I had to do GC, I carried over the same practice of running standards for the analyses of interest with every run, and using them to set retention times for each component for every analysis.
Because of that I don't have feel for how long a retention calibration is typically good for on GC...
But now I find myself in a situation where I have to rely on published retention indices for compound ID (and there can be hundreds of compounds!!!) for high probability compound ID, so the "calibration" is done using n-Alkanes to have the calculate the retention indices
In this case the run times are "VERY" long and I get a LOT of samples. So much so that it is hard to keep up, so the less I can run n-the alkane standards the better...
Mu question is what would be the longest reasonable time between running the alkane standards ...
This is R&D support for early stage process development, so there are no specific QC/QA requirements and the chromatograms can be very different with each experiment...
I do have more to go on than retention index, but a good retention index would really help nail things down... I do have an MS on the GC, but MS often does not ID the right isomer even for large peaks, and has a lot of trouble IDing the small peaks correctly... The MS hits ALONG with retention index would make the IDs much more reliable.
Thanks for any info.
- karen
- karen
