GC-NPD
Posted: Thu Nov 09, 2017 2:46 pm
by hts123
I was using the GC-NPD for testing of acrolein samples. However,the chromatogram of the blank is one with the solvent peak and another peak that resembles a big "leap" which leads to drifting of the baseline.
I had seen past examples of the similar samples ran by other analyst using the same method and same GC-NPD yet with beautiful symmetric peaks shown on the chromatogram.
I am unsure if the problem I have is due to the sensitivity of the NPD detector or due to my bad sample preparation....
I will really appreciate it if someone can have some idea regarding this.
Thank you.
seohua
Re: GC-NPD
Posted: Thu Nov 09, 2017 6:49 pm
by James_Ball
What are your method parameters such as: Column type, injection temperature, oven program, solvent, carrier gas and flow rate?
Many different things can cause problems, we need more information to help trouble shoot this one.
