Benzene and naphthalene: huge differences in FID response
Posted: Tue Dec 12, 2006 7:35 pm
I am analyzing a gaseous stream containing 0.5 % of benzene and 0.015 % of naphthalene in methane. This mixture is made by injecting a 5 % wt solution of naphthalene in benzene by means of a syringe pump into a methane stream. Transfer lines to the GC are held at 150°C. Sampling is made automatically.
The chromatogram shows the following area values:
(area C6H6) : (area C10H8) = 520000/144000 = 3.61
while the molar ratio is 0.5/0.015 = 33.3
So naphthalene shows a molar response factor almost 10 times higher than that of benzene !!!
Take a look at the naphthalene peak (http://mihd.net/eglzh7). It has a shoulder on the right...
Does anybody know what's going on?
Thank you. Christian
