GC/FID DMSO and column DB WAX (polyethylenglycol)
Posted: Thu Dec 07, 2006 2:22 pm
by demi_lune
bonjour,**
I have some problems with a solvent (DMSO: dimethylsulfoxide) and my column DB-WAX. in fact the profile of DMSO is not repeatable and i used this solvent as a diluent for elaborate a method of purity on a other solvent (Isobutylamine). Do you think that DMSO can react with my column?
Thanks....
Re: GC/FID DMSO and column DB WAX (polyethylenglycol)
Posted: Wed Dec 27, 2006 11:38 am
by stobs
Dear demi_lune,
because the boiling point of dmso is very high, i think vaporization of dmso in injector should be unstable. therefore the repeatability was not good.
as you know, volatile solvent is better sample solvent for gc analysis. :D
thanks,
bonjour,**
Thanks....
Posted: Wed Jan 10, 2007 6:40 pm
by demi_lune
thanks for your response stobs
