HPLC linearity
Posted: Wed Nov 29, 2006 2:45 pm
Hi Everyone,
This is probably basic question for most of you (apologies for that!), but I would like to know how to deal with the trendline from my linearity test going through the y-intercept.
i.e. To determine the response factor for my compound by HPLC, I measure the absorbance of a range of concentrations then construct a graph which gives a straight line. The line has a good R-squared value and I use the gradient as my reponse factor for measuring samples. However, the line passes through the y-axis above the origin. How should I deal with this in my calculations.
thanks,
Nick.
thanks,
Nick.
