Just a few other minerals. Would rather avoid SPE if possible and stick with a simple extraction and injection to HPLC.
The quicker and easier the better.
Extract with ether, using low actinic glassware, filter/centrifuge, and analyse by HPLC. Quick, easy, and probably inaccurate.
The protocols for HPLC vitamin tablet assays take account of the forms of Vitamin A and E used to make the tablets. The alternative is to use wet chemical protocols, such as the IUPAC vitamin A assay in USP <571>.
HPLC methods usually are validated for the formulation ingredients, and it's not uncommon for some multivitamin formulations to generate low results unless great care is taken to exclude oxygen and light, and minimise extraction time and heat.
I'd suggest contacting either the manuafcturers of the tablets or the vitamin ( eg Roche ), and ask for guidance, as they may have standard protocols.
