New to GC - dull questions for those with patience.
Posted: Sun Nov 26, 2006 1:14 pm
Hi all,
I'm new to Gas Chromatography, I have very little experience in this and no background in chemistry.
Is there anywhere on this forum that explains GC in layman's terms? If so, could you point me to it?
Alternatively, here's the little I know - any (and I mean any), additional information to this in plain English would be really helpful.
OK, as far as I know, different molecules move through the column at different speeds, that's how you tell what chemicals are in your sample (by the retention times). I've injected a binary mixture of MEK (butanone), and cyclohexane and managed to separate them. Then I can inject the samples separately and find out what the retention times are and compare these to my binary mixture.
Q1. The software I have integrates the peaks so I can find out the areas, these are proportional to the amounts of each component. How do I convert the areas to something meaningful, i.e. microlitres? I've heard Mol fraction mentioned but with my very limited knowlege in chemistry, I don't know that this would make sense to me. I do know how to make up a molar conc (mol wt in grams, in 1l water), but that's about it.
Q2. Suppose I inject and unknown sample (say, an oil), with lots of components. How do I identify these components from the retention times? Is there a resource that is used to find out a component from a retention time?
I'm not at work at the moment so I can't give the exact details of the instrument (but I doubt that's important). It's a Shimadzu FID GC with a 12 rack autosampler and a 30M (approx) BP capillary column. It's hooked up to a PC and running Shimadzu's GC solutions software.
Sorry for such basic questions, but I hope one of you can answer without boring yourself to death in the progress.
Thanks very much!
AM.
Thanks very much!
AM.
