Multiple peaks from one substance
Posted: Thu Sep 28, 2017 10:32 am
Dear friends,
I am studying metabolites of popular pharmaceuticals in the context of its presence in wastewater.
I am at the first stage of elaborating GC-MS method (Thermo Scientific TRACE 1300 GC, ITQ 900 Ion Trap Mass Spectrometer, Rxi-5Sil MS Cap. Column).
Now I work with metabolites of diclofenac, i.e. 4' hydroxydiclofenac and 5-hydroxydiclofenac (http://www.sigmaaldrich.com/catalog/pro ... ®ion=PL, http://www.sigmaaldrich.com/catalog/pro ... ®ion=PL).
Before analysis, analytes are derivatised with MSTFA (http://www.sigmaaldrich.com/catalog/pro ... ®ion=PL).
And the problem is I've got two peaks from 4'-OH diclofenac as well as 5-OH diclofenac (and actually diclofenac also).
4'OHD spectrum is: RT.15.28 - 190, 437, 402; RT. 16.21 - 302, 330, 455
5OHD spectrum is: RT. 15.62 - 437, 278, 402, 338; RT. 16.10 365, 455, 302
Diclofenac spectrum is: RT.13.45 - 190, 349, 314, RT. 242, 214, 367 (this second peak is for sure from diclofenac).
Ions are presented in descending intensities.
It is permanent situation (same results were observed from months). It is not about the column. Blank sample does not show any similar peaks.
As you can see the second peak of 4’OHD and 5OHD has similar spectrum but the intensities of ions are different. Is it possible for the second peaks to be the same compound while the intensities of ions are slightly different? And could it be some degradation product of both 4’OHD and 5OHD (I suppose they are not stable and reactive)?
In the spectrum of original diclofenac there is 190 ion most abundant in the first peak, the same as in 4OHD spectrum, in the first peak also. Is it possible for 4’OHD to be present in the spectrum of diclofenac, as a degradation product? But only the 190 ion is coincident...
Maybe some expert could give me a hint how I should interpret this results? I am planning to do stability tests for each compound, maybe it could give me some answer which peak correspond to the analyte and which is degradation product (??)... And of course I have to study fragmentation patterns of these compounds, however it is not so easy for me..
Please give me some links where I could extend my knowledge on the topic. I am fully aware, I have to learn a lot, but I have no chemical background so I ask for the help.
Thanks for your time!
