When you calculate Column Volume.......
Posted: Sat Nov 18, 2006 1:06 am
When Calculating Column Volume, do you use the Settled Bed Height for the height or do you use the packed Height for your height in the volume equation.
Im picking up an abandoned chrom process (it just so happens that i have no chrom experience) It turns out that our process has been run in the past using the settled Bed Height on TMAE and Q-sepharose Fast Flow columns, but there has been some speculation if this is the right way to calculate the CV.
