Perchloric acid in Methanol/ACN - UV absorption?
Posted: Fri Nov 17, 2006 3:57 pm
I'm using a gradient separation and my mobile phases are as follows:
A = 0.1% HClO4 in water
B = 0.1% HClO4 in a mixture of MeOH/ACN
I'm monitoring 220 nm.
My question/problem is this: Is anyone aware of an incompatibility with perchloric acid and MeOH/ACN? It appears that the UV absorption of my "B" mobile phase increases over a relatively short period of time (< 24 hours). This affects the sensitivity of the method and also my mood.
Thanks in advance.
Thanks in advance.
