Our lab uses our (UV-FL) HPLC to run EPA methods 610 and 8310. Lately I have had run initial calibrations almost every other day because benzo(a)pyrene's recovery fails high in the ccv after running the first or second sequence of samples. Any ideas on how to troubleshoot this problem ?
So far I have made new stock solutions to make sure that the problem isn't coming from my standards.
