SPME injection of Water
Posted: Tue Sep 19, 2017 5:34 pm
Hello all,
I was hoping you could help me with a question I am having. My lab recently received a GC-MS with liquid and SPME capabilities. The use of the instrument is to look at trace chemicals in distilled spirits. When the technician came out he had already created a method based on using the 40% ethanol with the SPME fiber. Since the column is a TG-1701MS I was concerned that the samples may be incompatible with the column but he assured me that everything would be okay.
Does SPME allow a water based solution to be introduced in a 1701MS column without significant damage?
Thank you for your help.
