Ideal Balance gas for GC analysis of CO2 reduction products
Posted: Fri Sep 15, 2017 9:17 am
by Nusrat
Hello All
I want to calibrate my GC to quantify reduction products from CO2 like CO, methane, ethene, H2, hydrocarbons. I am not sure which gas will be ideal for being a balance gas in my calibration units is co2 fine? or N2 is better?
Re: Ideal Balance gas for GC analysis of CO2 reduction products
Posted: Fri Sep 15, 2017 11:54 am
by GasMan
This depends on which detector you will be using. If you are using a TCD, I would suggest that the balance gas should be the same as the carrier gas that you are using, otherwise you will get a huge peak for the balance gas that may hide some of your peaks of interest.
Gasman
Posted: Fri Sep 15, 2017 1:03 pm
by Nusrat
Thanks @GasMan
I indeed am using TCD for their detection. What bothers me is i would be using mixture of gases in CO2 , so won't it be fine to have balance gas as CO2 itself?
Posted: Mon Sep 18, 2017 4:59 pm
by GasMan
Now I see what you are doing, yes it makes sense to have the balance gas as CO2.
Gasman
