Reprocessing Results in Chemstation
Posted: Thu Sep 14, 2017 8:12 am
I was running some samples with Chemstation but the PC crashed, which meant the sequence never finished and thus an HTM report was never produced.
However I did still obtain some chromatograms which I'd like to process into a report. Normally I would use the Data Reprocessing Mode in the the offline instance of Chemstation to do this; however when I try to do this it gives me the error message "Template sequences cannot be started in offline mode".
I've reprocessed data in this way before so I'm not sure what's changed. When I try it in online mode it starts performing injections and trying to re-run the entire sequence which is not what I want!
Thanks in advance for any help you can offer.
