Hydrogen peroxide by LC
Posted: Tue Nov 07, 2006 6:37 am
I found an article about the determination of hydrogen peroxide by LC, by using triphenylphosphine (TPP) as the reagent. TPP reacts with hydrogen peroxide in the sample and triphenylphosphineoxide (TPPO) is formed.
TPP and TPPO are easily separated on a short C18 column. So far so good. I have tried to use the method for samples with a lower H2O2 conc than described in the article and I have run into problems. The oxidation never stops! The longer I wait to analyse my samples, the higher are my results. I added 0.1 mg/ml of EDTA to the samples, and the results got more stable but are still increasing over time.
Can it be air that is causing this? What is the best way to prevent unwanted oxidation. He-sparging the samples will be hard since they contain acetonitrile.
