If you're not part of the solution....
Posted: Fri Nov 03, 2006 2:41 pm
by GOM
If you're not part of the solution...............
.......you're a gas or a solid!
Jimmy Carr 2006
Cheers,
Ralph
Posted: Fri Nov 03, 2006 4:24 pm
by PJ8
you're part of the precipitate.
http://www.toothpastefordinner.com/0109 ... lution.gif
The other cartoons on this site are well worth browsing through if you have the time.
Posted: Fri Nov 03, 2006 5:11 pm
by GOM
Yes, I prefer your version
Ralph
Posted: Sat Nov 04, 2006 5:07 pm
by Noser222
...then you're suspended!
Posted: Sat Nov 04, 2006 8:33 pm
by GOM
good one!
Posted: Mon Nov 06, 2006 10:54 am
by PJ8
Why did the white bear dissolve in water?
Posted: Mon Nov 06, 2006 10:58 am
by gcguy
'cause it was polar!!!
Posted: Fri Nov 10, 2006 11:41 am
by WK
I believe Jimmy Carr used to work in the petrochemical industry so he should know!!
WK
Posted: Tue Nov 14, 2006 10:57 pm
by Uwe Neue
What to do ...
when a lead turns into lead ?
