Ion-pair and peak shape...
Posted: Tue Sep 05, 2017 1:35 pm
Hello all,
I'm trying to use USP method for API verification. It's a gradient one and takes 72.1 minutes. Analytical column is 4.6-mm 25-cm; 3-mm packing L1, MP-A is 10 mM ammonium acetate and 5 mM sodium 1-heptane sulfonate, and MP-B is Acetonitrile and methanol mixture. The column and the system were equilibrated for 3 hours. At the beginning, we've got perfect peaks -Tailing factor: NMT 1.5 for both peaks-. However, after 10-15 injections, we lost system suitability; unacceptable peak shape. The column is new and used only for this analyze. Since it's USP method, we have to use it. Is there any suggestion? Regards.
