Remembering our teachers
Posted: Thu Oct 26, 2006 3:01 pm
How about quotables from our teachers instead, bert?
A start:
It must have been the first lecture in General Chemistry at the University of Denver (1961?). It was Fall. The prof. (can we name them??) lit a match, held it up and asked: What do you think has more heat, this match or the radiator (pointing to the radiators heating the lecture hall). We had a bit of trouble answering. He made it very clear that it was the radiators. It was his way of explaining extensivity and intensivity. In intensiveness the match was the winner, the temperature being much higher. The bulk (extensivity, total amount) of the radiators as well as their heat capacity was so much more that we were quite embarassed about having to think extensively about that ...(how many matches would it take to heat that water to 35° he asked further.)
This was the same prof. who, after explaining that if acetic acid was neutralized by NaOH one gets acetATE, asked what we will get when dropping NaOH on our shoes. We had no idea. His answer: Sodium shoeate.
A start:
