Hyphenating columns and LCMS problems.
Posted: Sun Aug 27, 2017 10:32 pm
Will hyphenating a gaurd column to analytical column cause significant pressure for LCMS for electrospray ionisation. I know the baseline noise is likely increased.
Are there any resources for performance of hyphenated columns research either for HPLC / LCMS as I could not find any. Like calculation based evidence or evidence of such research using one mobile phase which should be one dimension (am I correct?) because true 2D method has 2 mobile phases applied for a RP and then for IEX separation for example.
So is the option of coupling a analytical column to C18 column more expensive than using just a mixed mode column in terms of purchase/ operating costs?.
I want to know more of your experiences in this area as I am thinking about it.
Thank You.
Thank You.
