anything can decreae the retention time?
Posted: Wed Oct 25, 2006 2:18 pm
I found my retention time decrease as the number of injections increase.
It is not becuz of the flow rate. I use a TTBB which does not absorb on column to confirm it.
Is the water in the solvent can decrease the retention time>?
i am using a dancial chiralpak AD-H column
If there is the sth bulit on the column, the retention would not change too much between two continous injections. But in my case even between two injections ( the duration time is 15min) the retention time changed a lot.
Anyone has any suggestion for that??
i am getting crazy about it...
P.S i have flushed the column this afternoon. But it is of no use....
