CO2 Gas Analysis - 7890A GC - TCD
Posted: Thu Aug 17, 2017 10:19 pm
Hey,
So i want to be able to detect CO2 gas in my analysis but really confused about a whole bunch of things.
I decide to run my CO2 sample with the following configuration
Inlet Temperature at 270 deg C
Oven temperature starting from 50 deg C to a max temp of 270 deg C
TCD - 300 deg C
... but i really couldnt get a signal.
I have read in several papers that to analysis a permanent gas sample (e.g CO2), more than one column should is used and valves should be switched which I still don't fully understand.
My GC, as far as I know has or can only have one column installed at a time, (It is either a HP PLOT 5 - which i have at the moment or a HP PLOT Q.
Cheers,
Ajay.
TCD - 300 deg C
Cheers,
Ajay.
