salycilic acid
Posted: Mon Oct 16, 2006 9:46 am
hi everyone
i have this problem:
i have to analyse a tincture with salycilic acid and a NSAID.
column is an Alltima C18 250 *4.6
MP CH3CN/H2O 70/30
flow 0.6 ml/min
NSAID sample is prepared simply diluting tincture while salycilic acid sample is prepared diluting NSAID sample and adding 1 ml of H3PO4 10%.
the two analysis are consecutive but NSAID assay is always OK while salycilic acid assay is very unpredictable. It seems that autosampler can't inject the same amount from each vial, i say that becouse also the NSAID has a poor recovery and his behaviour is similar to an internal standard respect to salycilic acid. But it's impossible becouse NSAID analysis is OK so autosampler works.
Usually the second or third analysis seem to be OK while the first trial is a disaster...
What the problem?is the critical step tha addition of H3PO4? if it's so..where did salycilic go?an d why the second and third trial go better..
Help me to solve this problem...
thank you
vincenzo
MP CH3CN/H2O 70/30
flow 0.6 ml/min
thank you
vincenzo
