How to separate ADP and ATP using Hypercarb
Posted: Thu Oct 12, 2006 2:02 am
Hello.
We are using LC to separate nucleotides (AMP, ADP, ATP) for detection with MS.
We use Hypercarb (PGC) column, 150x2.1 mm, 5µm particle size.
Our solvents are:
A: 50mM NH4Ac + 0.1% monoethanolamine
B: 70% Acetonitrile + 50mM NH4Ac + 0.1% monoethanolamine
Gradient is 5-50%B in 10 minutes.
Using this configuration, we can detect nice peaks of nucleotides, but ADP and ATP elute at almost same retention time.
Can anybody suggest a way how to modify the configuration to separate these two compounds?
Thank you.
Ttomas
Our solvents are:
Thank you.
Ttomas
