Chemstation G1034c disks
I have a 5971/5890 smart card 1 which has happily run for years, however the computer has totalled the hard drive as well as the backup hard drive. so I am having to re-install,
I have the original G1034 install disks 5 3.5" floppies but 2 won't run so I am stuck, does anyone have .img files of the floppy disks?
I have G1034C rev C 02.00 MS chemstation, I have managed to image disks 1, 2 and 3 but not 4 or 5,
can anyone help? it would be a shame to junk a decent machine because of software.
thanks
Mike
Colin: good news, I have G1034C installation discs saved on my hard drive. We used this version on our 5890 GC with 5971 MSD.
Bad news: it's G1034C Revision C01.05 not the revision you had, that's what we used until boss retired the unit, so you'd need to load up this version, and I don't know what the difference would be (might be which version of Wondows it's compatible with). This one has four "discs", and somehow (when I knew how) I apparently made a zip file and an executable file, so each of those may contain all that is needed. Each file is about 6 MB, so I can E-mail those if you post your E-mail address here (like colin1 at xyz dot com).
fantastic, the files are going to be pretty much the same and I can just trick the software with disk labels to make ersatz disks
my email is colin at Leksing dot co dot uk
much appreciated
Colin - I sent the zipped file and the executable file with the extension changed by E-mail (more details in the E-mail). If neither of those work, I do have electronic copies of the four 3.5 inch diskettes and can likely put on a CD for you.
Thanks so very much, with a bit of messing about I was able to copy and replace the dead ver 2.00 files using the same file on the ver 1.00 disk to make the whole thing work as ver C 2.00 and now it is all back together.
learned a lesson here floppies die
DVDs die too. Image hard drives.
thanks so much for your help. you most certainly deserve good Karma,
best
colin
Nice that someone here could help.
Users browsing this forum: Google [Bot] and 12 guests
