Backflash Calculator
Posted: Wed Oct 04, 2006 2:07 pm
I regularly use the backflash calculator on Restek's website.
I have a 70mm x 2mm id liner and use methanol as sample solvent in a particular method. Therefore according to the backflash calculator I can only inject 0.1uL (and 0.2uL takes it over the liner volume).
My question is:
what effect does the split flow have on this calculation?
I use 100:1 at the moment - so to get more sample onto the column can I use 0.1uL and 50:1 or 30:1 etc?
Thanks in advance
WK
My question is:
Thanks in advance
WK
