Acetone or Iso-propanol which is better?
Posted: Wed Jul 19, 2017 6:13 am
by brainz
Hey,
I want to mix my sample of oil (Hexane & Decane) and Water to form a homogeneous mixture.
Acetone or Iso-propanol, which is better?
Re: Acetone or Iso-propanol which is better?
Posted: Wed Jul 19, 2017 6:54 am
by Peter Apps
Welcome to the forum.
Acetone probably, but if you have a very low fraction of either component it might make the mixture oily or wet enough to still separate. If you use enough of either solvent it will mix.
In the time it took you to post and wait for a reply you could have done the experiment.
Posted: Wed Jul 19, 2017 7:07 am
by brainz
Haha ... off course. I needed a second opinion.
Thanks for the response tho
Posted: Wed Jul 19, 2017 7:27 pm
by dap
Hello.
iPrOH seems to be better choice because of ultimate mixing properties.
Posted: Wed Jul 19, 2017 8:07 pm
by Peter Apps
Evidence outweighs opinion very time.
What was the first opinion ?
Posted: Thu Aug 17, 2017 10:00 pm
by brainz
Hello.
Hello Dap,
iPrOH - Isopropyl alcohol isn't this the same as Iso-propanol.
I havent used this yet, but i might just try it out.
Posted: Thu Aug 17, 2017 10:04 pm
by brainz
Thanks Peter,
From my Lab experience i noticed I needed more acetone to achieve a homogeneous mixture than isopropanol, that was why i asked the initial question.
