Building a field use gas chromat for hydrocarbons c1-c5. Any sourcing or reference material for constructing a 1/4" od poly flo column 6-8 ft long squalene packing how to.
I'd suggest you consider starting again. Ployflo is a polyethylene tubing that's thermoplastic. If you can't use the conventional GC column materials, then you need to choose a material that is impervious and can also cope with thermal conditioning of the column. If your system is disposable, then nmaybe PE would be suitable, but the alternatives aren't expensive.
Typical tubing is Stainless steel - no good for acid/corrosive gases; silica or glass - very common, and also possible to use alumina in a porous layer open tubular silica column; or PTFE - good if reactive compounds eg sulphur, are present).
Whilst an unsaturated hydrocarbon like squalene can be used as stationary phase, there are also more durable alternatives, such as Carbopack. I'd suggest looking at the catalogues of somebody like Restek, Supelco, Agilent for more details of possible systems.
There are small field GCs available for low molecular HCs, and the chromatographic systems depend on what process/environment you are sampling and what concentrations you want to detect. If you describe your needs, maybe somebody can offer more specific suggestions.
Bruce Hamilton
