PFTBA Fragmentation pattern
Posted: Mon Jul 17, 2017 10:19 am
by environeer
Hello Forum!
On an Agilent GCMS system (7890A/5975C) we weekly check if the recommended PFTBA- fragmentation conditions (69mz: 100%, 219mz:~50%, 502:~1%) are met, which was the case for months.
After cleaning the ion source and a following tuning procedure however, the PFTBA fragmentation pattern changed and now turns out to be: 69mz:100%, 219:~90%, 502:~10%.
Has anyone experienced this phenomenon before?
Re: PFTBA Fragmentation pattern
Posted: Mon Jul 17, 2017 12:17 pm
by dblux_
Hello Forum!
After cleaning the source you gained proper sensitivity for high masses.
Posted: Tue Jul 18, 2017 7:21 pm
by James_Ball
Also if there is still some water hanging around in the analyzer it will bias the high mass abundance. I usually let mine pump down overnight before tuning, and then after a week do it again just in case. It takes a while for all that metal to come to a thermal equilibrium, but once it does it holds for a long time.
Posted: Wed Jul 19, 2017 9:28 am
by environeer
Solved!
It turned out that a wrong/different tune file caused these issues. stune and atune were somehow mixed up and falsely attached to the current method.
Air/Water checks are performed weekly, and indeed, after maintenance on the MS, an adequate amount of time is given for proper equilibration.
Thanks.
Posted: Wed Jul 19, 2017 10:02 am
by dblux_
Solved!
But you don't invoke tuning procedure from analytical method, do you ?
Then, no matter what tune file is attached to the analytical method you may stune or atune instrument.
Posted: Thu Jul 20, 2017 2:53 pm
by James_Ball
Solved!
Could be the tune file that the method uses for operating parameters.
Posted: Fri Jul 21, 2017 7:32 am
by environeer
No. The tuning is done manually.
