Phosphate buffer wash
Posted: Fri Jul 14, 2017 1:27 pm
by Crevetus
When using a phosphate buffer system how frequently should one flush the entire system with water (not only the piston back-chamber) in order to prevent crystalization and wearing of the spare parts?
Re: Phosphate buffer wash
Posted: Fri Jul 14, 2017 2:12 pm
by Consumer Products Guy
I either kept the buffer flowing at a slow rate (even in a recycle mode with eluent going back into the mobile phase container) or I flushed the entire path (mobile phase reservoir forward through detector to waste line) with flush solvent made up similarly but without the buffer salts (phosphate) - every time.
Posted: Fri Jul 14, 2017 3:55 pm
by Crevetus
Thanks for the reply! So not even the column should be kept in the phosphate buffer...And at the end of the day either recirculate the phosphate or wash the entire system with water. The important issue behind this question are some ghost peaks obtained when injecting buffer through the column. They are somewhat reproductible but abnormal in my opinion.
Posted: Sun Jul 16, 2017 7:27 am
by HughMic
I either get fat burners for women here at a slow rate (even in a recycle mode with eluent going back into the mobile phase container) or I flushed the entire path (mobile phase reservoir forward through detector to waste line) with flush solvent made up similarly but without the buffer salts (phosphate) - every time.
Every time? Maybe I should be doing that too.
Posted: Sun Jul 16, 2017 10:05 pm
by tom jupille
This article from John Dolan's "LC Troubleshooting" series in LC-GC is almost 20 years old, but still very relevant:
http://www.lcresources.com/tsbible/26042008.PDF
Posted: Mon Sep 04, 2017 3:13 pm
Not water specifically: similar aqueous-organic mix but NO salts !
