Liner Volume
Posted: Fri Jul 14, 2017 2:46 am
by chromy2709
Hi all,
Can someone advise me on where I can get information of the effective volume of a Agilent 5183-4711 Split liner ?
I am trying to ensure that I use the right solvent so that it prevents back flush.
Thanks.
Re: Liner Volume
Posted: Fri Jul 14, 2017 4:41 am
by Poly Styrene
It has an 870 μL internal volume. :)
The Agilent calculator should have a built-in list of liners, no?
Re: Liner Volume
Posted: Fri Jul 14, 2017 7:09 pm
by James_Ball
Unless he is using an older version of Chemstation with the 5890. That list is very handy and I am glad they added it to the newer versions :) I can't remember if the volumes are listed in the online catalog or not, which would be a good idea too.
Re: Liner Volume
Posted: Sat Jul 15, 2017 4:05 pm
by chromy2709
Thank You.
Re: Liner Volume
Posted: Sun Jul 16, 2017 2:28 am
by mckrause
From James:
That is why we all used the H-P (pre-Agilent) free flow calculator; it had all the volumes of the H-P liners built into it. Sure saved a lot of catalog time!
Re: Liner Volume
Posted: Sun Jul 16, 2017 9:43 am
by separation97
From James:
Thanks James.
Im using LECO ChromaTOF software and could not find these information.
Will have to refer to the catalog.
