TCD for analysis of H2O, H2S, SO2, etc?
Posted: Fri Sep 15, 2006 11:50 am
I'm currently running an HP 5890A with capillary column and TCD for analysis of permanent gases (H2, O2, N2, CO, CH4, CO2, etc)
However, I would also be interested in analyzing for: H2O, H2S, SO2, SO3, and possibly even NOx's.
Obviously I'll need a different column, such as the Supel-Q PLOT (not sure if this can elute water?). If I use helium as a carrier gas, would it be possible to detect ppm or low % quantities of these gases with a TCD? Theoretically it looks possible, but I'd like to hear what others use for this analysis, both columns and detectors.
Thanks!
Thanks!
