Alternative Chromatogramm / Mass spectra Analyzing Software
Posted: Wed Jun 28, 2017 8:24 am
i am using a Pegasus III MS-ToF - coupled with a comprehensive GC System.
The Software I use to analyze the generated data files is the Chromatof software (provided by Leco). Due to several reasons - I am trying to find an alternative to that.
One reason for example is the low resolution Picture of the chromatogram I get when I try to export the plots. For publications I need a high res PNG/BMP format and cant get it to work. Tried PDF export with silly high DPI Values but the 2D-Chromatogram is still as pixelated as the one generated by simply using the copy plot function - and paste it into Excel/Word/...
I know there are some software solutions that read data from many different manufacturers (e.g. Bruker, Agilent, Waters...) I guess, but I didnt find any thrird party Software that can read and work well with the Leco Data files.
As its comprehensive GC the software needs to be capable of doing a deconvolution step in order to generate the 2D Plot.
I tried a timed Demo of the ACD/Labs Processor - which kept crashing after crunching the data for an hour straight though.
