Problem with column module, temperature
Posted: Wed Jun 14, 2017 4:22 pm
hi!
Im working with an Agilent 1100 system, and Empower as software.
We have different systems, some are heat systems so we can have our samples cold, but these systems should also work with regular samples..
my question is:
when im running my sample set, the heat compartment wont turn on.. the method is set for 50 celcius, but nothing happens. the analysis is running, but my RTs are totally out because the temperature is out of hand..
have any of you any advice for me?
my question is:
