HPLC of ALKALOIDS
Posted: Thu Aug 31, 2006 5:37 am
Well Hi,
I will be working on HPLC method development of isolated plant alkaloids and i have a very limited budget. Is it ok if i choose a C18 reverse phase column or is there a better RP column for separation of alkaloids . I have a 515 semi prep pump with UV-vis detector and an empower software. If later after validated method developed i thought of doing LC-MS where in the LC i have a binary 2695 binary pump (waters) and xterrra C8 column hyphenated to Zq4000 ESI probe with single quadropole.
Can anyone tell me whether Iam in to the right direction or do I have to rethink the whole strategy.
Thank you
John
Thank you
John
