GC-MS high base line
Posted: Sun Jun 04, 2017 5:09 pm
Hi all,
This is my first post here. I'm using GC(7890B)-MS(5977A) for my research.
The following problem happened after I modified the path of a column (which was directly connected to MS) by connecting it to a column splitter (which was equipped in the GC chamber but wasn't used), and letting one of the outlet go to MS, and another outlet go to FID. I'm sorry I didn't vent the MS while I did the modification. I didn't change the GC configuration for the modification.
Then, when a sample was injected, both FID and MS can give sample peaks together, but a high and stable base line with abundance of 3500000 was observed in TIC (which used to be no more than 5000). MS fragments were from 28 (N2) and 32(O2) (peak intensity ratio of 4:1). The turbo pump seems working with 100% speed, but why 'Hi Vac' displays 'N/C', and I didn't hear any sound when it was initiated. I've tried the following actions but they didn't help: 1. tighten the column connections. 2. let the pump work for overnight. 3. vent and then pump down the MS and reboot it.
The AutoTune could pass, but the EM volt is as high as 2872. I found that there is no peak if I manually decrease the EM volt. Under such high EM volt, only the most abundant sample peaks as well as the high base line can be observed.
Does anyone could help me on these issues? Thanks!!
Best,
Haohong
Best,
Haohong
