- admin
- Site Admin
is there switch valves available which you can place between online purification column and an analytical column? You could then have this directed to waste e.g during 0-3 min and to analytical column after 3 min within an injection? Can you get this valve controlled by standard software? Please give references, where can I find this. Many thanks.
By tom jupille on Thursday, August 19, 2004 - 12:53 pm:
Click on the "Rheodyne" link near the upper right of the Forum. They are probably the largest manufacturer of HPLC switching valves and injectors.
