Ethanol and Formamide Testing
Posted: Mon May 29, 2017 12:41 am
Hi Everyone
Currently working with a USP method where we are testing for ethanol and formamide in an API.
Our results for ethanol is comparable to that on the CofA. Our result for formamide is not. We do not detect formamide at all.
We see formamide in the standard, we have performed recovery (spiking formamide directly on the API and by adding formamide to water solution then adding that to the sample). We get ~105% recovery with excellent precision <2.0%. Thus we suspect that we are having an extraction issue.
The procedure for extraction is as follows:
120 mg of API, accurately weighed, to a 15-mL centrifuge tube, and dissolve in 2.0 mL of m-xylene, heating in a water bath at 45 ± 5°, if necessary. Add 2.0 mL of water, mix, and centrifuge. Transfer the m-xylene layer to a 15-mL centrifuge tube, and extract with 2.0 mL of water. Discard the upper m-xylene layer, combine the two retained lower aqueous layers, add 1.0 mL of Internal standard solution, and mix.
Can anyone offer some advice on where we might be going wrong in the sample preparation stage?
Thank you,
Thank you,
