Pal CTC /gerstel
Posted: Sun May 28, 2017 4:52 pm
by marek2
Does anyone know if this CTC Combi Pal can work with GC? Or its some version of LC Pal. Generally I found that combi pal is dedicated for GC but why there is an LC valve installed?
http://www.ebay.ch/itm/CTC-Analytics-PA ... Swn-tZKCBV
Second question, can Gerstel sampler be controlled via Cycle Composer?
thanks
Marek
Re: Pal CTC /gerstel
Posted: Mon May 29, 2017 6:46 am
by Peter Apps
That valve is probably for gas sampling. Best to contact the seller, then you can use any answers if a dispute arises.
Posted: Tue May 30, 2017 7:07 pm
by Jake
Yes, as the name implies "Combi"-PALs can be used for either GC or HPLC. That blue valve box is the standard injection port for HPLC. The loop is the sample loop. I've used these a lot. Warning: they're robust, but not particularly precise. Didn't matter for me since they were used with samples with internal standards. And I have a lab full of Combi-PALs doing GC injections.
No idea about the Gerstel/Cycle Composer question.
Posted: Tue May 30, 2017 8:08 pm
by marek2
Thanks Jake!
