FID air leak
Posted: Mon May 15, 2017 6:51 pm
I'm new to the forum and relatively inexperienced with gas chromatography systems. We were having issues lighting the FID on one of our 5890s. While troubleshooting we disconnected the air line coming to the detector weldment from the flow manifold to measure flow. That flow was about 440mL/min. With the line reconnected to the weldment we measured about 400mL/min at the top of the collector body using the o-ringed flow meter adapter. Is this common or should we have the same flow at both points?
Thanks in advance,
Tom
Thanks in advance,
Tom
